1996 Mercury Cougar tranny throwing oil?
208,645 MILES • V8 • 2WD • AUTOMATIC
PATRICK CARTER
  • 5 POSTS
I sent my car to a repair shop over a blow pcm. The tech called me back and said that he hasn't got to my car yet but says he can already tell the tranny needs to come out cause it is throwing oil. He probably meant tranny fluid. However, that seems to be a bold statement for someone who hasn't checked the car yet. Also,if the car won't run than how do you know it is throwing fluid and not just leaking or seeping from the gasket? Am I stupid to feel like this is a shady remark. Isn't it easier to fix the pcm and start the car and have it running at operating temp to find or pinpoint things of this nature.
May 1, 2008 at 9:03 AM
MERLIN2021
  • 17,250 POSTS
It might just be his way of saying it leaks, if there is a puddle under it, it could be obvious!
May 1, 2008 at 9:24 AM
PATRICK CARTER
  • 5 POSTS
I see your point. However there is no puddles under car and it has not leaked anything for 2 years. Just left my driveway yesterday and no puddles under car but perfectly clean pavement. I took a look at pan and it was dry on exterior. Little confused and don't want to be ripped off!!!
May 1, 2008 at 11:23 AM
