1996 Mercury Cougar no turn,flasher or brake lights
ANTEOMNES
Electrical problem
1996 Mercury Cougar V8 Two Wheel Drive Automatic
what would cause all of these at once? there is also a slight buzzer noise around the headlight switch.
Jun 27, 2010 at 6:39 PM
BLUELIGHTNIN6
  • 16,542 POSTS
most likely culprit would be faulty turn signal switch. the brake light circuit as well as the others mentioned all run through the signal switch..
Jun 27, 2010 at 6:50 PM
