1995 Mercury Cougar HEADLIGHT INSTALL
NORA R
1995 Mercury Cougar 6 cyl
HOW DO I INSTALL THE FRONT PASSANGER SIDE HEADLIGHTS. WHAT TOOLS WILL I NEED AND CAN A FEMALE DO THIS? I PLAN ON BUYING USED HEADLIGHTS AT A JUNK YARD IF THIS MATTERS.
Mar 11, 2010 at 5:46 AM
BLUELIGHTNIN6
  • 16,542 POSTS
1.Make sure the headlamp switch and time delay switch are in the off position. 2.Raise hood and disconnect wiring from each of the two bulbs. 3.Using snapring pliers, spread the three metal retainers attaching lamp assembly to grille opening panel, from the rear of panel. Pull straight upward to disengage and remove metal retainers. 4.Remove the lamp assembly from vehicle, then remove the bulbs. Reverse the procedure to install. 5.Turn the lights on to check for proper operation.
https://images.2carpros.com/forum/automotive_pictures/261618_1_144.jpg
Mar 11, 2010 at 5:54 AM
NORA R
SORRY FOR NOT MAKING MY SELF CLEAR. I NEED TO REPLACE THE PLASTC COVER FOR THE TURN SIGNAL AND HEADLIGHT COVERS (LENS). FOR THE FRONT PASSENGER SIDE. THE BULBS ARE FINE. BUT I WILL KEEP THE INFORMATION YOU SENT WILL BE HANDY ONE DAY.
THANKS GUYS!
Mar 11, 2010 at 6:44 AM
