1995 Mercury Cougar Brake lights not working
1995 MERCURY COUGAR
PAULPORTER56
Electrical problem
1995 Mercury Cougar V8 Two Wheel Drive Automatic
As previously recommended I changed the brake light switch located on the brake peddle, and I still have no brake light (tail or third). I have checked the fuse and have power to the fuse block and the appropriate fuse. Brakes are working well, just bled them. Im out of ideas, any suggestions?
May 2, 2008 at 9:59 PM
Depress brake pedal and look for power at brown wire at light bulb socket-do you have it? If so test the ground black wire continuity.
May 3, 2008 at 2:59 PM
