1994 Mercury Cougar no warm air
138,000 MILES • 6 CYL • 2WD • AUTOMATIC
BRIAN69
My cougar heater is blowing cold air. Engine temp hasn't changed. All hoses are hot after warming up the vehicle. I can hear the little door that allows air to flow over the core opening and closing. Do you think the switch that goes cool air to hot is bad?
Oct 9, 2010 at 1:18 AM
  • 75,988 POSTS
Try replacing the thermostat and also check the heater control valve, and also the air blend door-
Oct 9, 2010 at 8:35 AM
