Disconnect the negative battery cable-find the PCM behind right kick panel unplug the wiring connector/s to it -be extra care when plugging it back-those tiny pins they bend easily when not inserted properly
Nov 28, 2008 at 12:08 PM
ANGEL2EYES01
MEMBER
can you show me what the pcm looks like and the kick panel so i am sure i replacing the right part.
Nov 28, 2008 at 12:14 PM
✓Experienced Mechanic
The right kick panel is at the passenger side where your right foot be at when sitting down -you will see an access door -the PCM wiil look similar like below
