1994 mercury cougar 8 cyl
1994 MERCURY COUGAR
DJWHOO2005
where is the trouble code hook up located? will the transmission rapid studdering go away if i change the fluid and filter? It also begins to idle rough after a few minutes while in gear, just replaced a vacuum hose that was leaking, it helped(doesnt stall anymore) seems to be getting better.. any suggestions? should I paint it yellow with red the red interior? I cant find anyone that ghas done that ! I think i t would loook good.. Thanks. have a nice day
Nov 27, 2007 at 10:38 AM
BMRFIXIT
  • 19,053 POSTS
[quote:e0d0ae73a2="DJWHOO2005"]where is the trouble code hook up located? will the transmission rapid studdering go away if i change the fluid and filter? It also begins to idle rough after a few minutes while in gear, just replaced a vacuum hose that was leaking, it helped(doesnt stall anymore) seems to be getting better.. any suggestions? should I paint it yellow with red the red interior? I cant find anyone that ghas done that ! I think i t would loook good.. Thanks. have a nice day[/quote:e0d0ae73a2]
Its located under the hood by the strut
You cant use an OBDII reader on yours
You need to get the engine running tip top have you check for tune up
And changing tranny fluid and filter always a plus
Good luck
Nov 29, 2007 at 11:32 AM
