1993 Mercury Cougar bad vibration?
TRUCKER1
Engine Performance problem
1993 Mercury Cougar 6 cyl Two Wheel Drive Automatic
As soon as the car is started it starts to shake and vibrate until you start to accelerate. Fuel mileager has dropped from 22 to 15. Have tuned it up with new plugs and no improvement. As soon as you slow back down the vibration returns.
Mar 4, 2010 at 12:56 PM
ERNEST CLARK
  • 1,730 POSTS
Check all of your vacuum lines and fittings for leaks. Also, check your fuel pressure regulator. Pull off the vacuum line and check for the presence of fuel. If there's any, replace it.
Mar 7, 2010 at 1:23 PM
