1992 Mercury Cougar firering
1992 MERCURY COUGAR
150,000 MILES • V8 • 2WD • AUTOMATIC
JUNIOR MARTIN
my car will run fine for a while and then just out of the blue it will quit firing and I will get out and take the coil wire if and sumtimes it will start firing, co I changed the coil, dastibuter cap, roter button and the coil wire and it will just stop firing again but now it's getting to where it wont even fire when i mess with the coil and so on,but it can set for a while and start wright up and run fine untill it's ready to do it again a day or 2 later...it's a 5.0 ho
Jul 28, 2009 at 6:38 AM
DOCFIXIT
  • 18,828 POSTS
I'll put my money on a whacked out Thick Film Ignition Module located behind right head light.
Jul 28, 2009 at 7:27 AM
Next time it won't start check for fuel and spark
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor cam and crank sensors- Note: If it doesn't apply disregard it
Jul 28, 2009 at 7:33 AM
