1989 Mercury Cougar headlight assembly removal/replacement
DEACONSCOTT
1989 Mercury Cougar
HOW DO I REMOVE THE HEADLIGHT ASSEMBLY?
Jun 24, 2010 at 7:53 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Make sure the headlamp switch and time delay switch are in the off position. Raise hood and disconnect wiring from each of the two bulbs.
https://images.2carpros.com/forum/automotive_pictures/261618_0900c1528006bb74_1.jpg
Using snapring pliers, spread the three metal retainers attaching lamp assembly to grille opening panel, from the rear of panel. Pull straight upward to disengage and remove metal retainers. Remove the lamp assembly from vehicle, then remove the bulbs. Reverse the procedure to install. Turn the lights on to check for proper operation.
Jun 24, 2010 at 9:40 AM
