1989 Mercury Cougar Driverside Window
62,000 MILES • 6 CYL • FWD • AUTOMATIC
MYSCION1
Sometimes it works and most times it doesn't. It is also the case with my 1995 Ford Taurus.
Aug 29, 2010 at 12:09 PM
BLUELIGHTNIN6
  • 16,542 POSTS
need to remove door panel and inspect wiring at the window motor and switch. if wiring is good than either the motor or the switch is failing. when it doesn't work, can you hear the motor trying to operate?
Aug 29, 2010 at 3:26 PM
