1988 Mercury Cougar 6 cyl Automatic 72800 miles
Hi, on my 1988 cougar I have an electronic cluster with the warning lamps on each side. I have been noticing that my low fuel lamp wasent activating when I had low fuel and also my low washer lamp wasent either. The only lamps that work are my parking brake lamp. The check oil, check amp, check engine, and the seat belt lamp which only comes on when I start the car, which I guess it normal but. Other then that none of the lamps turn on for there specific operations.
If you guys have any idea what might be causing this problem let me know.
Thanks for your help!
Friday, July 17th, 2009 AT 11:25 AM
