1985 Mercury Cougar Battery problem?
160,000 MILES • V8 • 2WD • AUTOMATIC
LILJDGMAN08
I have a 1985 mercury cougar, i bought it about a month ago, and its been running fine. All of a sudden one morning i go to start it and it wont start, it just makes this loud clicking sound. So i got a jump and it was fine, until i turned it off. After the jump if i turn it off for twenty minutes or so it will run again, but if i wait an hour i notice it will just start clicking again. i went to autozone and had a free testing and it said the battery was dead, so they charged it and it came out fine. So i put the battery back in and it ran fine for a day, then when i get up to go to work in the morning, i went to cut it on and it sounded like the car was having a hard time staying running. it ran for about 5 minutes while warming up, then the lights dim and radio cuts off, so i turn the car off and tried to start it back up and thats when it started clicking again. Is their something draining the battery or a possible shortage anywhere? Your help will be gratly appreciated.
Oct 26, 2008 at 8:58 PM
  • 75,988 POSTS
Hi liljdgman08 and welcome to 2carpros Get the alternator load tested find out if its producing the correct output-if it checks out-Get it check for an excessive parastic draw-could be a short circuit within the electrical system-
https://images.2carpros.com/forum/automotive_pictures/12900_parastic_draw_1_39.jpg
Oct 26, 2008 at 9:05 PM
LILJDGMAN08
I have a multimeter, i believe i ajusted it right, i tried it out, but it really isnt reading anything. It keeps coming up numbers like, 1.56 etc, low numbers, am i doing something wrong? when i disconnect the negative battery cable from its post, where do i put the red and black cables on the multimeter at? please help me. also when i get it jumped now, if i turn it off at all ther battery just dies on me right away.
Oct 27, 2008 at 8:36 AM
  • 75,988 POSTS
Put the meter on the DC 20 scale
The DVOM black lead goes to the disconnected negative cable- the positive battery cable remains connected-if there's a short the meter will read battery voltage-Now start removing fuses one at a time-when the reading drops to zero-this is where the trouble circuit is-
Oct 27, 2008 at 8:42 AM
