1973 Mercury Cougar clunking when put into gear
130,000 MILES • V8 • 2WD • AUTOMATIC
DAVID JORDAN
My 1973 cougar does not go into gear smoothly when starting from a stand still. I don't think it is a too fast idle problem. Is there a vacum that could be of fault? What else could be the problem.
Mar 7, 2008 at 5:29 AM
MERLIN2021
  • 17,250 POSTS
Check U-joints, tranny mounts, and engine mounts.
V acuum modulator on the side of the tranny can be checed to see if it holds vacuum..
Mar 7, 2008 at 6:05 AM
WICKEDLYCOLD
  • 6 POSTS
i'd check the drive train axel bearings. or possibly your u joints. get under the car and see if you can get any work out of the driveline
Mar 19, 2008 at 6:22 AM
