1972 Mercury Cougar Car heats Up to much
DANIEL626
  • 1972 MERCURY COUGAR
Engine Cooling problem
1972 Mercury Cougar V8 Automatic
I have a 1972 mercury cougar xr7. And wanted to know why it heats up so fast. I replaced the water pump, Radiator, thermostat, radiator hose. Could it be that I need a new transmission filter?
Wednesday, September 24th, 2008 AT 9:23 PM
Got white smoke coming out of the tail pipe? If so could mean a blown headgasket, cracked head or block-get it block and pressure tested. Fans coming On or fan clutch working properly.
Try bleeding the system could be air lock-
Wednesday, September 24th, 2008 AT 9:33 PM
DANIEL626
How do you bleed the system?
Wednesday, September 24th, 2008 AT 11:55 PM
If it doesn't apply keep going. You didn't answer my Q is it? If not do below
BLEEDING COOLING SYSTEM
Always bleed air from cooling system after replacing coolant. Set heater for maximum heat. Remove radiator cap. Loosen drain plug and remove drain bolt (if equipped) from engine block. Drain coolant reservoir. Fill coolant reservoir to MAX mark with 50/50 water-coolant mixture. Loosen bleed bolt and fill radiator up to base of filler neck. Close bleed bolt when coolant flows out without bubbles. Tighten bleed bolt. With radiator cap removed, start and operate engine to normal operating temperature. Add coolant if necessary and check for leaks.
Thursday, September 25th, 2008 AT 1:33 AM
DANIEL626
White smoke has came out probaly like twice that I notice. It starts to heat up when im at a stop light.
My car Does not have a A/C Compressor could that be a possibility?
I Appreciate the help
Thursday, September 25th, 2008 AT 12:49 PM
Get the cooling system block and pressure tested
Thursday, September 25th, 2008 AT 12:52 PM
