1963 Mercury Comet
BGMIKE
Engine Performance problem
1963 Mercury Comet 6 cyl Two Wheel Drive Automatic
how to replace distributor on a comet
May 11, 2009 at 7:44 AM
HMAC300
  • 48,601 POSTS
take the distributor cap off, remove the one wire from the coil. Unbolt the clamp on the block that holds the distributor in. Mark where your rotor is pointing with a piece of chalk on block or nearest part. pull distributor out and replace putting the rotor back to chalk mark. Reassemble and check timinig.
Oct 8, 2009 at 11:55 AM
