1961 Mercury Comet no fire new coil
1961 MERCURY COMET
COMET MAN
Electrical problem
1961 Mercury Comet 6 cyl Two Wheel Drive Automatic
i have a 1960 comet. i was getting no fire so i changed the coil. new wires, distrubeter everything. there is still no fire coming from coil. checked ground and power, all good. any suggestions
Sep 25, 2009 at 6:08 AM
DOCFIXIT
  • 18,828 POSTS
Maybe shorted condensor recommend replaceing points and condensor. If good with dist cap off crank is there spark across points?
Sep 25, 2009 at 6:22 AM
Also check the resistance wire between coil positive terminal and ignition switch to include gapping the contact point or use a dwell meter
Sep 25, 2009 at 6:28 AM
