90 Topaz brakes
SQONE
I'm having a hard time getting the rear drums off the hubs. I've tried wd 40, heat and still no luck. Any ideas?
Thanks
Sep 22, 2007 at 8:32 AM
MERLIN2021
  • 17,250 POSTS
If backing the adjuster off doesn't do it, Remove the outter bearing and put the tire back on, pull while shaking back and forth!
Sep 22, 2007 at 9:49 AM
SQONE
I can get the drum/hub off the car but cannot get the hub off the drum.
Thanks
Sep 22, 2007 at 10:19 AM
MERLIN2021
  • 17,250 POSTS
You do not want to! even if you are replaceing the drum, buy one that is put together! or you'll regret it!
Sep 22, 2007 at 11:01 AM
