1993 Mercury Capri Need Help
99,845 MILES • 6 CYL • 2WD • AUTOMATIC
CHILDUVGOD
When standing, the engine idle will decrease & engine will run real rough and die or try to die. Mechanic has tried all the computer diagnostics, fuel injection service, new distributor cap, rotor, and wires, mass flow air sensor, fuel pressure regulator valve, and the fuel filter replaced. Have any ideas?
May 21, 2008 at 3:07 PM
  • 75,988 POSTS
Inspect and test the idle speed control bypass air solenoid, the throttle position sensor, EGR valve and recheck the fuel pressure.
May 21, 2008 at 3:26 PM
2CARPRO JACK
  • 11,533 POSTS
Is it idling so low that it misses and dies or is it missing that is causing the stalling. If the idle continues to drop, I would start with the IAC , they can become sticky and or slow causing a stalling/low idle, although testing ok and not seting any codes
May 23, 2008 at 12:35 AM
