1993 Mercury Capri belts
130,000 MILES • 4 CYL • 2WD • MANUAL
PYROGIRL9127
I just had the belts replaced in my car, and they are still squealing very loud. especially when i turn the car on and when i use the air conditioning.
Feb 14, 2009 at 4:45 AM
RACEFAN966
  • 5,029 POSTS
OK so how tight are the belts? Do they have a lot of movement when you push down on the power steering belt or the A/C belt? Here is a pic so you can see which belts I am refuring to.
https://images.2carpros.com/forum/automotive_pictures/249564_Graphic_42.jpg
Feb 14, 2009 at 5:03 AM
PYROGIRL9127
the tension on both belts is really tight. i dont think this is the answer.
Feb 14, 2009 at 7:32 AM
RACEFAN966
  • 5,029 POSTS
Well either the a/c belt is not tight enough or there is rubber on the pulley's and that is making the noise or the a/c compressor is locking up.
So get a spray bottle of water and as it runs with the a/c on spray the a/c belt and see if the noise stops. If it does then the a/c belt has been glazed or is not tight enough or there is lots of rubber on the pulley. Also check to see if the a/c compressor stops turning when you turn the a/c on if that happens the the a/c compressor is no good and needs to be replaced with the reciever dryer. Let me know what you find.
Feb 16, 2009 at 2:32 AM
