1991 Mercury Capri
ERVINKING
Transmission problem
1991 Mercury Capri 4 cyl Front Wheel Drive Manual
how do i change the clutch slave cylinder
Apr 28, 2010 at 2:49 AM
  • 75,988 POSTS
This vehicle uses two types of clutch release systems. Turbocharged vehicles with type G transaxles use a mechanical cable system. Non-turbocharged vehicles with type F2 transaxles use a hydraulic clutch system.
1.Disconnect hydraulic line from slave cylinder and plug to prevent fluid loss.
2.Remove two retaining bolts, then slave cylinder.
3.Reverse procedure to install, noting the following:
a.Torque retaining bolts to 12-16 ft lbs .
b.Fill reservoir and bleed clutch system.
https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
Apr 28, 2010 at 8:16 PM
