1985 Mercury Capri timing chain
1985 MERCURY CAPRI
50 CAPRI
Engine Mechanical problem
1985 Mercury Capri V8 Two Wheel Drive Manual 0
I have a 85 Merc Capri with a new 351w in it im trying to start it but its not getting gas to the cylinder is it posable that the timing chain was not put on with piston on exaust stroke? What valve would open before compression stroke?
Sep 16, 2008 at 10:18 AM
If its not getting gas it will not start up -check the fuel pressure to rule out a defective fuel pump.
Sep 16, 2008 at 10:32 AM
50 CAPRI
i have 7 to 9 lbs of fuel pressure and spark just not getting fuel to the cylinder
Sep 17, 2008 at 2:49 AM
