2000 Mercedes Benz V280 Engine misfiring
70,000 MILES • 6 CYL • 2WD • AUTOMATIC
GFG
Hi gentlemen technicians,
I own a Mercedes v280 with factory fitted lpg system
Ihave never used lpg since bought three months ago
I have a misftre I hope my info is correct as I am going on the say of my mechanic friend who has been working on the vehicle in question.
I bought the v280 3 months ago without the misfire,two weeks later developed my current misfire problem.
Ihave spent £600. with my mechanic doing the work that I was advised to do my an exmercedes mechanic
This merc mechanic gave me a diagnostic which didnt do well in identifying the specific problem, a couple of codes were p1108 continuous positive, p1010 lamda sensor signal wire, p1037, idle speed control adaption,
p1319 minimum stop throttle valve sensor and some referance to a faulty lamda sensor,?? the same mechanic told be to start from the ground up so I changed plugs ht leads, my mechanic checked compression ok injectors ok ? bought two from breakersyard .com and my mechanic changed an existing duff one of the two I bought, new injector ring seals, new manifold gaskets,fuel filter, I bought a cheap ign coil to test existing ok, I have not tried air mass sensor yet , well the costs are becoming an issue
I am at the point where i wonder if I have lost the vehicle,,, sold a melon so to speak, Could the timing chain be the problem I dont know Please can you help I am more than willing to donate but have problem transfering money over the net at this time,give me your address and I will send you donation cheque
Thanks gents hope you can help in some way, curiuos to read any possible replies Regards Gerry
Jul 19, 2010 at 7:03 AM
  • 31,937 POSTS
Hi there,
Is this misfire show up as an induction backfire, a miss fire under hard acceleration, or a general rough running misfire that has no particular pattern?
mark (mhpautos)
Jul 19, 2010 at 10:45 PM
