1997 Mercedes Benz SLK320 Ride height
48,000 MILES • 4 CYL • 2WD • MANUAL
RAGON0311
I have a ´97 slk 230, the both tires on the right side of the car are exactly 1 inch higher than the left. i measured the ride height from the rim to the fender well on each tire. i looked under but saw nothing bent or out of the ord. Can this be fixed by an alignment shop. Thanks for the help.
Nov 9, 2008 at 5:42 AM
GFIMOTORCARS
  • 673 POSTS
First I would recheck the ride height. The proper way to measure your ride height is with wheels straight ahead. Then with your tape, measure from the ground through the middle of the rim to the fender. If your ride height is still incorrect I would suspect a suspension component is posssibly worn. Your local alignment and suspension shop should be able to handle a ride height issue in this vehicle.
Jan 3, 2009 at 12:38 PM
