2002 Mercedes Benz SLK230 How easu is to raplace Motor oil
22,000 MILES • 4 CYL • 2WD • AUTOMATIC
CHEMISTII
Can you describe how to replace motor oil on this vehicle? I've heard that oil filter is on of engine. Oil can be removed from Dip stick by pumping .
If possible please explain!
Thanks and wish you a happy new year!
Dec 30, 2009 at 5:54 AM
RACEFAN966
  • 5,029 POSTS
There should be a drain plug in the oil pan (bottom of the engine), put a drain pan under it and remove the plug and drain the oil.
Mar 14, 2016 at 3:19 PM
