cilinders 2 and 4 on my 1998 slk230 are not working check engine light is on contineously. Could it be a sensor or a foulty computer.
Jan 27, 2010 at 1:20 PM
✓Experienced Mechanic
Hi there,
The check light is indicating that there is a fault code set in the ECU, you will first have to get a scan done to read these codes, you may have to have this done at a dealer as general workshops may not have the scanner interface to suit your Benz.
