2007 Mercedes Benz SL600 sudden change in engine noise
NJDOODLE
Engine Mechanical problem
2007 Mercedes Benz SL600 V12 25000 miles
while driving car, engine suddenly started making unusual engine noise. Sounds almost like it is in overdrive. Car idles fast but no pressure on brake pedal. it is a higher pitched hum which follows the acceleration of the engine. sound like it is working too hard. Dealership says they don't hear anything. Anyone that has ridden or driven the car notices immediately. Do you know what this might be? Possibly a Turbo bearing?
Sep 23, 2008 at 4:14 AM
2CARPRO JACK
  • 11,533 POSTS
could be, might also be something more simple, like a problem with the accessory drive. Try taking the Benz tech for a ride with you, or see if they have another car on the lot you can start to have them listen to so that you can point out the noise. If it is idling higher, then there must be a problem with something
Sep 24, 2008 at 12:43 AM
