1997 Mercedes Benz SL500 passenger side window won't go up
1997 MERCEDES BENZ SL500
DONALD SOLOMON
Electrical problem
1997 Mercedes Benz SL500 V8 Two Wheel Drive Automatic 70.000 miles
passenger side window will not work,window motor
works, fuse good,new switchses installed.Can not
locate problem
Oct 25, 2009 at 1:47 PM
  • 31,937 POSTS
Hi there,
If the motor is working, is this via the switch? if so the problem must be with the regulator or the motor drive gear, you will have to pull the trim and inspect what is going on with the regulator.
mark (mhpautos)
Oct 25, 2009 at 2:11 PM
DONALD SOLOMON
[quote:134a28b5b6="mhpautos"]Hi there,
mark (mhpautos)[/quote:134a28b5b6]
Thanks for your reply window will go up or down if direct battery cables is conected to window motor
Oct 25, 2009 at 2:44 PM
  • 31,937 POSTS
You will have to work back from the motor plug, checking power through the switch, make sure that the relay is ok, how many wires to the motor? if 2 the problem may be with the change over relay, check this out, i will look for a manual and try and get some more exact information.
Mark (mhpautos)
Oct 25, 2009 at 2:58 PM
