1994 Mercedes Benz SL500 convertible top
1994 MERCEDES BENZ SL500
12,200 MILES • 6 CYL • 2WD • AUTOMATIC
DG9343
top doesn't always work when switch is engaged..to get it to work when not operating top you have to drive ablock or two and then press switch and the top goes thru the proper operation..
May 16, 2008 at 8:21 AM
GINGERPCURRY
First of all you might run a check on your charging system the convertible will not work properly if the battery is not charging correctly or if it is too low. Found that out with mine had a bad alternator........and 2nd are you sure you have a v6 in it? I seriously thought they only put a v8 in the 1994 models.
sincerely
ginger
Oct 19, 2008 at 12:05 PM
