it is a mercedes wire and it does have several #'s on it . I don't believe it went to the factory stereo because all those were taped off and ziptied together. I say its not causing problems, but i really have no clue because im not sure what is really bad or just not qorking for moment due to electrical. from what im gathering this yr/model 93 500sl at 80,000 seems to have or develop wiring and air mass problems along with cooling system. Ive just ordered radiator and then i will have to address these issues. Depends on the day what works and what shorts. Today it seems like the alternator, but suppose it could be wires touching draining battery. very frustrating. I have a wiring diagram not sure if this is the only one but i really cant read, but both these color wires independantly seem to go to cooling system in some capacity if im reading correctly and on pic it points in the vicinity of the passenger side around qhwre you would plug computer?diagnostic in, but im not mechanic just been forced to figure out myself . Its a mess, but thank you for your time and help.
Sep 12, 2009 at 3:12 AM
