After installing front brake pads the pistons will not come back out when depressing the brake pedal.
Aug 4, 2008 at 3:33 AM
2CARPRO JACK
✓Experienced Mechanic
Did you pump them several times? brakes move a surprisingly small amount of fluid to move the piston.If so, you may have jammed them in the bore when depressing them to install pads.
Aug 5, 2008 at 12:52 AM
