1995 Mercedes Benz SL320 Cooling Fans
1995 MERCEDES BENZ SL320
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
1LITTLECASTLE
What is the problem and how do I fix the non-operable, two electric cooling fans in front of the radiator that are supposed to activate upon activation of the car's A/C? The fuzes and relays are fine and the fan blades turn freely by hand.
Jul 4, 2009 at 10:02 AM
2CARPRO JACK
  • 11,533 POSTS
I have forwarded your question to our M/B tech. He will be with you shortly, thank you for your patience
Jul 9, 2009 at 12:56 AM
GFIMOTORCARS
  • 673 POSTS
First thing to check is that you have power going to this circuit. If you have power at the electrical connector for the fan then your fan has burned out and needs to be replaced. If you have no power at the fan or fuse for the circuit let me know and we will start tracing the circuit back.
Jul 14, 2009 at 4:28 AM
