1990 Mercedes Benz SL300 Battery discharge
93,000 MILES • 6 CYL • 2WD • AUTOMATIC
HUMVEE
I have a 1990 SL300 that the battery goes dead after a day. The car is usually stored in a heated area but now its in an unheated garage. This problem just seemed to start when we had our fisrt real freezeing temps.
I hooked a Snap-On graphic meter between the battery. Bypassed the trunk light and the meter read a 0.110 amp draw. I have done the following tasks without finding the problem or reducing the draw. Removed fuses and fuseable links in 3 fuse boxes one at a time. Disconnected the alternator. Removed the aftermarket radio. Car is completly original and well maintained. The exception is that an aftermarket radio was installed a couple of years ago.
Could there be a stuck relay?
Is there a fuse or fuseable link not located in the 3 boxes?
Backfeed from one circuuit to another?
Is there a timer icircuit that is not shuting down?
Any ideas would be helpful.
Thanks
Dec 13, 2009 at 1:57 AM
BUDDYCRAIGG
  • 2,262 POSTS
wow, you have tried everything that I would have suggested that a normal person with a limited tool box to do.
the next thing to do is start tracing every circuit after you print out the schematics.
Dec 13, 2009 at 6:59 PM
HUMVEE
I guess it's time to start pulling the dash.....thanks
Dec 14, 2009 at 12:09 AM
BUDDYCRAIGG
  • 2,262 POSTS
I tried looking at the schematics for any hidden fuses or links, but my on-line program has chopped the manual up so bad that I couldn't follow the pages.
Do you have a manual with a good wiring diagram in it?
Dec 14, 2009 at 4:08 PM
HUMVEE
Mine are also in about 20 sections/groups. At least they are not in German.
Dec 16, 2009 at 8:24 AM
