2002 Mercedes Benz S600 ABC Visit Workshop Message
AMAAMOUN
Suspension problem
2002 Mercedes Benz S600 V12 Two Wheel Drive Automatic 56k miles
I had the car battery changed. Since then I am getting the annoying "ABC Active Body Control Visit Work Shop"
message. I checked the ABC fluid and it seems low. I ordered a liter of CHF11s online and should get it in a day or so. Do you think this will take care of the problem? Thanks.
Jan 27, 2010 at 7:32 AM
WRENCHTOSS
  • 16 POSTS
It may but most likely you will need to find a shop with a scanner capable of clearing or resetting the codes the ABC system should reset itself after several starts if the ABC pump is putting out enough pressure..
May 21, 2013 at 12:30 PM
