1994 Mercedes Benz S600 ASR dash light
SKYLOWKAC
Engine Performance problem
1994 Mercedes Benz S600 V12 Two Wheel Drive Automatic
asr light comes on and car loses power.
Dec 30, 2008 at 8:45 AM
BOMBZ
if you are speeding up when the light comes on ,It means the wheels are loosing traction and the car will apply the brake to that wheel to try and stop it and if you keep the power on it will start cutting the power of the engine to TRY and stop you ,,,,if you turn the asr off (so light is on all the time ) you can go out and smoke those hides ,because these babies have got some go ,because with 400 odd horses they will spin up in some odd places when you least expect it , happy smoking
May 2, 2009 at 9:38 PM
COOLPHIL
  • 12 POSTS
when you loose power during ASR lights on your transmission is on limp home mode, the problem arises from the throttle actuator potentiometer, throttle actuator harness and or engine harness deterioration. if non of the above symptoms are present then you need to adjust the bowden cable, the one with the black plastic arrow on top of the laft throttle actuator
May 24, 2009 at 9:59 PM
