2001 Mercedes Benz S500 service b
WHITECC16
2001 Mercedes Benz S500 V8 Automatic 158000 miles
what has to be done on a service b. Is it worth 185 dollars?
Mar 29, 2009 at 8:27 AM
GFIMOTORCARS
  • 673 POSTS
B service:
Oil and filter change, check and adjust fluid levels, replace interior cabin filter, check all belts and hoses, inspect wiper insert, inspect brake pads and measure rotors, inspect and rotate tires, check all lamps, correct tire pressures, reset FSS counter, perform 32 point inspection.
This is worth $185. Most places this is what an A service will run you.
Apr 8, 2009 at 5:19 AM
