2001 Mercedes Benz S500 PAss Side turn signal on mirror
84,000 MILES • V8 • 2WD • AUTOMATIC
ACPARLA
Pass side mirror turn signal goes out. LED light works, but seems a bad connection. If you tap it it will work for a day or so and then off. Pulled mirror tryed to clean and put back. Same results. Trying to avoid $600 relacement mirror. Any suggestions?
Jul 6, 2008 at 1:14 PM
MASTERTECHTIM
  • 4,750 POSTS
besides totally disecting unit and trying to repair a bad solder joint, if you can find one, your only option is to replace the light. have you tried a salvage yard? 600 is alot of clams.
Jul 7, 2008 at 10:50 AM
