1996 Mercedes Benz S500 Window Regulator
1996 MERCEDES BENZ S500
117,000 MILES • 6 CYL • 2WD • AUTOMATIC
PARHAMAL
We are tying to install a new regulator per the dealer. We installed it, but it continues to click at a certain point. when we remove the motor and control it w/o the motor connected it goes up and down as normal.
Jun 18, 2008 at 11:19 AM
GFIMOTORCARS
  • 673 POSTS
If the regulator is not making noise out of the vehicle then you may have a problem with the motor. Does the motor click at any point when operated without the regulator. If not then you may want to check your window run channels for proper alignment.
Jan 4, 2009 at 5:25 PM
