I had to remove the battery cable and then this started ?
Jul 30, 2010 at 11:33 AM
✓Experienced Mechanic
Disconnecting the battery will cause the computer to lose its programmed memories-the computer has to relearn itself this maybe what's happening-if the problem was not there before you disconnect the battery
