2001 Mercedes Benz S430 stall when moving off
2001 MERCEDES BENZ S430
150,000 MILES • V8 • 2WD • AUTOMATIC
CHUFGY
when moving off from standstill hesitation and either stalls or jumps forward quickly
Jul 9, 2010 at 8:25 PM
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard
Jul 10, 2010 at 5:25 PM
