2002 Mercedes Benz S320 Stuck in first gear !
99,100 MILES • 6 CYL • 2WD • AUTOMATIC
RADGER
The History: About 4 weeks ago when cold weather started I noticed that, when I drove off first thing in the morning, my car was not automatically changing up through the gears (I mention the cold weather because I thought something may have become frozen with temp down to -11 at night). I tried to change gear using Tiptronic but no joy. So I stopped, put it in PARK and turned off engine. Then restarted and tiptronic worked fine. Drove off again in DRIVE and everything was working perfectly with smooth gear changes (up & down). A few days later had similar issue and resolved it by repeating the same process. It happened a couple more times since and resolved again as above. Then this morning, stuck in 1st gear again but despite stopping and trying my original "solution" it would not move through gears and Tiptronic did nothing (still displays "DW" on instrument cluster).
Other things that I have also noticed since the big freeze is that (a) the central locking fuse kept on blowing every morning I unlocked the car when frozen - I assumed that as the boot was frozen stuck that this may have been the cause as this hasn't happened since the milder weather; (b) when I push the S/W switch (Summer / Winter) it has no affect and will not change from its current setting (W). I mention these two points in case they are somehow relevant.
I have no warning lights on. Vehicle has just passed the 99k miles mark and has been regularly serviced at MB garage (I am not working anymore so would prefer to try and avoid going to MB garage for financial reasons).
Any help / advice very much appreciated.
Jan 13, 2009 at 5:06 AM
GFIMOTORCARS
  • 673 POSTS
Unfortunately this sounds like your shift control module may be failing. I have seen this before with a similar complaint however the cold was not involved. I am under the assumption that the cold is probably not helping the control module solenoid actuation (this is the mechanism in the shift control module that mechanically shifts the transmission). This is not a job that can be diagnosed or repaired at home as it requires coding and mating the control module to the vehicle. Proper diagnosis will require reading shift point pressures from the transmission via the Mercedes Benz STAR diagnostic computer. My best suggestion is bring it to a reputable dealer.
Jan 13, 2009 at 12:13 PM
RADGER
Many thanks indeed for your timely response. Sounds like it could be expensive then !
I will take your advice and get it to a specialist.
Jan 13, 2009 at 7:34 PM
RADGER
Thanks again. I just tried to leave some feedback but it said I did not have any points ! Not sure what that means.
Cheers anyway
Jan 13, 2009 at 7:45 PM
