1994 Mercedes Benz S320 reverse not working
1994 MERCEDES BENZ S320
200,002 MILES • 6 CYL • 2WD • AUTOMATIC
PSSTENN
My mercedes will not go into reverse at all. It just stalls. Everything else works just fine. The drive gear works perfectly but when in reverse, it may as well be in park. Can you give me some idea of what it may be?
Apr 15, 2010 at 2:48 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation.
As you have Drive, the torque converter and oil pump is working, i would be thinking that the problem may be with in the valve body, is there any feel of movement? does the car load up in gear? with this problem i would suggest that you get a transmission specialist to do test and report as these transmissions are quite complex and the prospect of doing a home repair is not very practicable.
Mark (mhpautos)
Apr 18, 2010 at 11:24 AM
JAMIE81FTW
my trans drive and rest forward works revers engages but does not move
Jun 11, 2012 at 6:56 AM
RIVERMIKERAT
  • 6,110 POSTS
Jamie, same recommendation: If the trans works fine in Drive, you most likely have a valve body issue. When was the last time you had the transmission serviced; ie fluid and filter changed?
Jul 20, 2012 at 8:52 AM
