I have found a few oil drops under the car very few
(5or6) and cannot find the source.
Apr 16, 2008 at 2:09 AM
GFIMOTORCARS
✓Experienced Mechanic
If it does not appear to be coming from the oil pan or any other engine areas then check your suspension bushings and motor mounts. These are oil filled and when they crack they will tend to leak small amounts of oil, i.e. drops of oil. Specifically your motor mounts and lower control arm bushings.
