1997 Mercedes Benz S320 ASR & ABS LIGHTS ON.
1997 MERCEDES BENZ S320
75,000 MILES • 6 CYL • 2WD • AUTOMATIC
JBANGER
When I am pressing breaks then ASR & ABS lights stay on also back stop light not working...?
Feb 19, 2009 at 12:40 PM
GFIMOTORCARS
  • 673 POSTS
This sounds like you may have a failed stop lamp switch. This is located under the dash off of the brake pedal lever. Failure of this will cause the Abs/asr lights and rear brake lights to fail. It is a fairly common failure part
Feb 19, 2009 at 4:58 PM
