2000 Mercedes ML320 Window Won't Go Up
MERCEDES BENZ
YOLE
MY WINDOW WILL NOT COME UP. WHEN I PRESS THE BUTTOM TO PULL THE WINDOW UP, I CAN HEAR IT WORKING IT SEEMS IT IS WORKING, HOWEVER IT MIGHT BE THAT SOMETHING GOT LOOSE, BUT CANNOT TAKE OFF THE PANEL. I WANT TO KNOW HOW TO TAKE OFF THE PANEL ON A 2000 ML 320.
May 28, 2006 at 5:10 AM
LSUSSEL
  • 252 POSTS
You first must remove the door panel. there should be screws on the side of the door. Second of all dont attempt to raise the window it might do more damage. the window part, the glass sounds like it got off track.
Jun 1, 2006 at 3:45 PM
Suggested Repair
Do not try to raise the window further, as that may cause more damage. Remove the door panel using the screws on the side of the door and check whether the window glass has come off its track.
Conversation Summary
The owner of a 2000 Mercedes-Benz ML320 says the power window will not go up, although the motor can be heard when the switch is pressed, and asks how to remove the door panel. The expert advises removing the panel by the side screws, not forcing the window up, and says the glass likely came off its track.
