mercedez benz 380se 1985
1985 MERCEDES BENZ
MXFIELDS
my 1985 380se stalls when i remove my foot from the gas and press the brades the rpm drops down while driving.. sometimes shut off.some time contiune to run. 2 aux fan does turn on i changed aux fan switch and check fan conect good
Feb 7, 2007 at 5:47 AM
BRUCE HUNT
  • 3,754 POSTS
Generally what you are looking at is a locking device that is out of alignment or failing. The brake pedal is an intricate part of the system. There is a switch/sensor on the brake pedal that tells the tranny shifter it is ok to shift. Start there.
Dec 6, 2006 at 11:29 PM
