mercedes car alarm problem
MERCEDES BENZ
JLMELONE
Help --I have a 1990 300E 4 Door and the car alarm is going off when I open the door with my key ( which I believe is a factory key).
I would like to disconnect the alrm and NEVER use it again -without affecting the rest of the car. Any ideas??
Dec 29, 2006 at 9:21 AM
SAVVAS
HAVE YOU GOT A KEY FOR THE ALARM WHICH IS SITUATED IN THE ENGINE COMPARTMENT.
Jan 8, 2007 at 9:13 PM
2HOWARDS
  • 16 POSTS
Give this a try, as you open the driver door the is a black oval plastic cover (about the size of a quarter). Pry this out with a with your fingers and this is the alarm connector. Pull the connector apart wrap some tape around it so it doen't fall into the door and reinstall it. Give it a try and this should resolve it. What's wrong?? I would think the switch on the drivers door handle (to replace this you need to get a new door tumbler also).
Hope this helps
Jan 24, 2007 at 12:40 PM
