Mercedes Benz air conditioning issue
MERCEDES BENZ
ASKFL7
I have a 1992 300D. When the a/c works it cools the car beautifully. However after driving for a short or long distance it seems like the compressor just quits. If I turn off the ignition and restart the car the a/c comes back on. Any thoughts please?
Thank you very much.
askfl7
Sep 29, 2007 at 1:13 AM
GREENWOOD
Is it hard to change a cam sensor on your own?
Oh ya, in a 96 taurus wagon.
Jul 18, 2007 at 10:49 AM
MERLIN2021
  • 17,250 POSTS
Check the evaporator for a temp sensor, sounds like the core is icing up.
Sep 29, 2007 at 1:38 AM
MERLIN2021
  • 17,250 POSTS
Additional info, If you have manifold gauge set take readings and post here! The reason is the sensor shuts it down, we aren't talking about a block of ice, only mild icing...could be other issues too, need readings if you can...I will look into it further in the am!
Sep 29, 2007 at 1:42 PM
BUZZSAW
  • 1,198 POSTS
[quote:792084cf5b="askfl7"]I have a 1992 300D. When the a/c works it cools the car beautifully. However after driving for a short or long distance it seems like the compressor just quits. If I turn off the ignition and restart the car the a/c comes back on. Any thoughts please?
askfl7[/quote:792084cf5b]
the air temp sensor is in the dash, its about the size of a quater, with 3 or 4 slashes in it, around radio or light switch area, put a small peice of tissue over slots with air on, if tissue sticks there its working (no thick paper, kleenex ) cycling ign switch resets system you have a prob and it could be 6 or 7 different things
Sep 30, 2007 at 10:52 PM
MERLIN2021
  • 17,250 POSTS
Here are the testing proceedures, see if they help...It would be real good if you know about using the manifold gauges!
https://images.2carpros.com/forum/automotive_pictures/62217_ac1_copy_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_ac3_copy_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_ac4_copy_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_ac5_copy_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_ac6_copy_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_ac7_copy_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_30961_mitchell_2_55.jpg
Oct 19, 2007 at 7:09 AM
