Mercedes Benz 300E differential subframe
1930 MERCEDES BENZ
RIZLEY
I have a 1989 300E Mercedes with 110,000 miles, it has developed a hard shift or jerk to the right as it shifts from first to second and slightly from second to third. This appears to be in the rear end, maybe a differential mount of some sort. Have you heard of this before and if so what might the problem be and how hard is it to perform the fix myself?
Sep 21, 2007 at 10:00 AM
BUZZSAW
  • 1,198 POSTS
[quote:7e3a1546f9="rizley"]I have a 1989 300E Mercedes with 110,000 miles, it has developed a hard shift or jerk to the right as it shifts from first to second and slightly from second to third. This appears to be in the rear end, maybe a differential mount of some sort. Have you heard of this before and if so what might the problem be and how hard is it to perform the fix myself?[/quote:7e3a1546f9]
a flex disc may need replacing, its like a u joint on the drive shaft
Sep 21, 2007 at 3:21 PM
