headlight lens replacement
MERCEDES BENZ
TOMBO
I need to change the headlight lens on my 2000 c230. It looks pretty easy. It looks like I just pop off the clips and replace except for one clip next to turn signal lens. do I have to remove the side lens in order to replace? :?
Dec 27, 2006 at 2:00 AM
2HOWARDS
  • 16 POSTS
First check to make sure the lens is available. If and I mean IF you can get one ask the dealer to print job # AR82.10-P-1829EB which will explain the operation. You may be able to buy the lens on-line. However there is a US law that was put into place (about 1993) preventing replacement of these due to the fact that the reflectors were/are damaged creating reduced light output.
Hope that helps
Jan 24, 2007 at 11:56 AM
TOMBO
I guess that explains why the dealer wanted to charge me $700 for a whole new headlight assembly. Thanks, I got the lens and replaced it.
Jan 25, 2007 at 12:23 AM
